Página 1 de 2
Baterias Tesla NCM made in CHINA RED ALERT WARNING
Enviado: 03 dez 2025, 18:57
por EVUber
A EV clinic da Croacia que se dedica a reparação e substituição de baterias colocou um RED ALERT WARNING acerca das baterias do tesla model 3 e model Y que utilizam as baterias NCM 811 da LG fabricadas na CHINA
fonte: https://electrek.co/2025/12/01/tesla-mo ... pair-shop/
We are raising serious concerns about Tesla Model 3/Y LG NCM811 battery packs (LGES Nanjing), which exhibit very high failure rates and significantly shorter lifespans compared to Panasonic NCA packs (Made in USA).
Ja anteriormente foi divulgado que as baterias LFP fabricadas na China exibiam degradação anormal devido as suas condiçoes de fabricaçao que existem um ambiente sem humidade no processo de fabrico.
Nem tudo o que vem da china vem com alto controlo de qualidade....
Re: Baterias Tesla NCM made in CHINA RED ALERT WARNING
Enviado: 03 dez 2025, 19:03
por EVUber
Media hype around “Made in China” battery systems being the “best” has never been confirmed in real-world practice.
We are raising serious concerns about Tesla Model 3/Y LG NCM811 battery packs (LGES Nanjing), which show extremely high failure rates and a noticeably shorter end-of-life compared with Panasonic NCA packs (Made in USA).
In over 90% of the cases we receive, cell-level repair is not possible on LG packs. The cell degradation within affected modules is far beyond anything that could be restored. The issue is rarely a single bad cell—most failing modules contain multiple cells with extremely high internal resistance. Out of 46 cells, it is common to find 15 cells over 100 mΩ ACIR, and the remaining 30 cells above 50 mΩ ACIR.
Given these patterns, adjacent series groups measured in parallel modules often show resistance values already above acceptable limits. This means that even if we replace the faulty cells with used, matching donor cells (never with new cells), the remaining weakened cells are likely to fail in a cascade. This makes the repair operationally unsustainable, as the entire pack is clearly nearing end-of-life, exposing us to extremely high warranty and labor costs.
Another unknown is this:
If one out of four modules is badly degraded, what are the chances that replacing a single module will result in a stable pack, and for how long?
Is it realistic to expect another 100,000 km of trouble-free use after replacing one module?
Most likely not.
At this moment, during ongoing experimental testing with real customers experiencing LG failures, we are losing over €20,000 per month in operational time while investigating whether LG’s Chinese NCM811 systems can be sustainably repaired. At this stage, we can confidently say: the cells are, to put it mildly, catastrophic. Panasonic has mostly single cell falire at 250,000km, and it is repairable, where LG hasmultiple cell failur.
For reference:
•A healthy Panasonic cell typically shows ~10 mΩ, while a new LG Nanjing cell starts around 28 mΩ.
•A failing Panasonic cell reaches ~28 mΩ, which is what LG cells measure when brand new.
It is extremely difficult to explain this complexity to customers.
The only alternative we can responsibly offer—although very rarely—is replacing the entire battery pack with a used Panasonic pack from the secondary market.
This brings us to a fundamental question:
Where does the media hype come from claiming that Chinese-made cells are “better”?
In practice, the best Li-ion cells are made in Europe (LG Chem, Samsung SDI) and the USA (Panasonic).
China’s strength is limited primarily to LFP technology, but Blade-format LFP packs are entirely non-repairable researched by independent institutes.
Important Notice for Tesla owners with Chinese LG packs
Due to extremely high operational losses, we must introduce an experimental “repair check feasibility” fee to determine whether repair is even possible.
If the pack is deemed non-repairable, the only options are:
1.Replacement with a used Panasonic pack
2.Full pack replacement at a Tesla Service Center
When supplying used Panasonic packs, we do not guarantee range, charging speed, or long-term capacity.
Warranty covers functional defects—not degradation or reduced range.
This article also serves as an official disclaimer.
Reference Data
Part number: 17000012-00-B
OEM price: €15,355 (excl. tax, EPC)
EVC repair check: €1,200 non-refundable (remove/assemble)
Waived if repair is possible
EVC full repair: €5,500 (excl. tax)
EVC Panasonic swap: €8,000 (excl. tax)
Estimated End-of-Life (EOL)
•Panasonic packs: ~400,000 km
•LG NCM811 (China): ~250,000 km
fonte:
Enviado: 03 dez 2025, 19:48
por civic
Pois, hoje fui bombardeado por essas noticias, o problema dessas LG já vêm dos Jaguar, Hyundai e grupo VW, vamos ver o que diz a Tesla.
Enviado: 21 set 2026, 16:36
por rjspedition
.. e depois das LG, agora são as BYD a correr os grupos:
Captura de ecrã 2026-09-21 163502.png (122.07 KiB) Visto 48627 vezes
Tem aparecido no meu feed vários posts sobre isto: Carros com uso mais intensivo em Espanha a dar erro nos packs BYD.
E pelos vistos, não é só Espanha:
Enviado: 21 set 2026, 21:54
Eu teria cuidado em dar significado a reports que aparecem em feeds das redes sociais ou motores de busca. É como avaliar o estado da saúde de um país à porta do Hospital... Normalmente as pessoas saudáveis não entram no Hospital (exceto os profissionais que lá trabalham, claro).
Dito isto, acho que se deve estar atento, mas sempre com atenção a este viés.
Vejo "huge" e "massive" mas não vejo números concretos de taxas de avarias, por exemplo.
Enviado: 21 set 2026, 22:45
por EVUber
Também ja tinha visto, os taxi espanhóis estão a cair uns atras dos outros
Para entender o problema um "especialista EV de Barcelona" da a sua opinião
Enviado: 21 set 2026, 23:53
por EVUber
No video aos 10m41s é dito
Teslas Taxi
3 condutores a trabalhar turnos de 8 horas no mesmo Tesla
Carregamento supercharger atras de supercharger :shock: :shock:
As baterias nunca chegam a arrefecer, se estão a falhar aos 75.000km muito ja aguentam....não existem Milagres
Enviado: 22 set 2026, 00:40
por pms
E nos comentários do video do JCTaxiElectrico há alguem a referir algo sobre o sistema de refrigeração:
Yo probe varios dias un BYD Atto 3 y un Tesla Y con las mismas baterías en teoría. Durante los mismos desplazamientos el Tesla sobrecalentaba las baterías y salía el aviso de que desactivaba la frenada regenerativa por sobrecalentamiento de baterías. El Atto3 jamás sobrecalentó nada las baterías en el mismo desplazamiento. Hace dos años al ver eso me decidí a comprar el BYD porque creía que algo no iba bien con las baterías del Tesla. Eso si el tesla hacia mas kms con la misma bateria que el BYD pero sometiéndola a más temperatura. Creo que el sistema de refrigeración líquida que usaba Tesla con esas baterías no estaba fino, recordemos que BYD las refrigera con gas, no con líquido. El diseñar coches que sean compatibles con muchas baterías provoca que no se optimicen como debe, el que mucho abarca poco aprieta. Tampoco entiendo por qué Tesla tarda 3 meses en sustituir las baterías cuando BYD con las que salieron defectuosas en menos de un mes tenían el coche listo con batería nueva recien llegada de China, y esto era hace años porque ahora seguro que con el stock que tienen será mucho menos tiempo. Y también está claro que las baterías de BYD no son reparables, a mi me lo dijeron en la propia BYD: nuestras baterías no admiten reparacion ya que el pack es indivisible por eso la carga al 100% siempre es esencial para preservar su vida. Si a la batería le pasa algo la única solucion es meter batería nueva. Y otro detalle que me parecía criminal es que si el propio fabricante no las cargaba a más de 90 kw por qué Tesla las sometía a 175 kw de carga rápida. No se Rick pero me temo que a Tesla se la suda la duración de sus baterías siempre que la estadística les sea favorable al período de garantías.
De facto no meu não me lembro de ver temperaturas acima de 35C... mas ainda não monitorizei um carregamento rápido em detalhe. No dia a dia chega aí aos 32C nos dias quentes, mas na garagem anda sempre 24-26C. Condução 27-29C por aí, vai até aos 31 ou 32 em dias de maior calor, mas em alguns módulos apenas, acima dos 29C liga logo a refrigeração, etc.
Caso a acompanhar. Estou curioso para perceber se o problema parte das células, ou parte da forma como é assemblado o pack/refrigeração/gestão da bateria/etc? (Porque não me parece haver este tipo de ruído com problemas semelhantes nos BYD ao que sei.)
Enviado: 22 set 2026, 04:59
por Nonnus
mjr Escreveu: 21 set 2026, 21:54 Eu teria cuidado em dar significado a reports que aparecem em feeds das redes sociais ou motores de busca. É como avaliar o estado da saúde de um país à porta do Hospital... Normalmente as pessoas saudáveis não entram no Hospital (exceto os profissionais que lá trabalham, claro).
Acho que isto diz tudo;
EVUber Escreveu: 21 set 2026, 23:53 No video aos 10m41s é dito
Teslas Taxi
Dizer que há carros que avariam massivamente porque as baterias dão o berro sem perceber (ou ocultar) o uso abusivo que teem, é tratar o assunto com muita leviandade.
Enviado: 30 set 2026, 22:09
por rjspedition
De acordo!
Achei curioso no entanto que após ter visto 3 ou 4 videos sobre isto no feed em Espanha, ter pesquisado e ter encontrado logo um tópico do outro lado do mundo.
Infelizmente o resto é um problema actual, qualquer acontecimento é logo "massive" e "super-mega-importante" para captar a atenção, mesmo quando ainda não há dados em volume suficiente.
E isto sim, também me deixou logo curioso por tamanha diferença.
