Não tinha ideia que já existiam apps para instalar nos telemoveis/tablets que mostram parametros do barramento de CAN (OBD2) como é o caso deste (que pode comunicar via bluetooth com adaptador do lado do carro):
https://play.google.com/store/apps/deta ... torquefree
Será que daria para ver o SOC do LEAF?
PS: encontrei isto, mas não sei se ajuda:
http://www.mynissanleaf.com/viewtopic.php?f=44&t=5442
[IMG]
https://lh3.ggpht.com/fjkR6HyCRfcwJTUBP ... Q_uvrvgGGo[/IMG]
[IMG]
https://lh5.ggpht.com/XaKCGdlXlkZAi3h9i ... _SG_xLAteE[/IMG]
http://www.youtube.com/watch?v=Ay-ZvTn3fLo
Descrição
Measure vehicle BHP & Torque
Clear car OBD DTC faults,
View data in Google Earth
See what your car is doing in realtime, get fault codes, sensor data and more!
An OBD II engine ECU diagnostics tool that uses a cheap bluetooth ELM / OBD adapter to connect to your car OBD2 engine management system
Some features include:
* Shows and Resets engine fault codes / DTC trouble codes stored in your car
* Can export map/track log files to Google Earth KML / CSV
* Engine performance data(0 to 60, 0-100, quarter mile, etc) (full version)
* Head up Display / GPS HUD mode perfect for checking your speed at night
* Data Logging functions including web upload and file logging, you can even upload data to your own web server from sensors you choose
* Customisable dashboard with theme support - setup the dashboard with the gauges and dials that you want
* Can help you fix your car and helps keep car repair costs down!
* Turbo Boost gauge support for VW vehicles (in Pro version only)
* MPG for Petrol/Gasoline vehicles. (Pro version has diesel support)
This is the free/basic version - it lets you get a feel for the application and lets you find out if it works with your vehicle / obd2 adapter combination; but may contain some small bugs including not working on some nissan/chrysler/subaru ECUs. The paid version has support for more vehicles and ECU types, looks a lot nicer, and works with more cars / trucks
The paid version has more features (HorsePower,Torque, 0-60 , quarter mile tests, graph data, map / track views) + no adverts and exra dial/display types! and better ABS / Knock sensor support, Transmission temperature support for some makes of car / trucks (GM / Ford, etc), and Turbo Boost on many more vehicles (including VW)
Works on vehicles made by Ford, GM/Vauxhall/Opel, Chrysler, Mercedes, Volkswagen, Audi, Jaguar, Citroen, Peugoet, Skoda, Kia, Mazda, Lexus, Daewoo, Renault, Mitsubishi, Nissan, Honda, Hyundai, BMW, Toyota, Seat, Dodge, Jeep, Pontiac, Subaru and many more vehicle makes, European, US, Far East, etc. Some vehicle ECUs may support more/less features than others.
**PLEASE NOTE!** Any reports of hanging or freezing after quitting the app is due to a bug in the HTC Evo 4G and Galaxy Tab, this can be triggered by using the Pandora/Vlingo/Aldiko bluetooth enabled apps. Disabling Pandoras new bluetooth settings fixes the problem, but HTC/Samsung need to release a fix. Please contact their support and encourage them to fix, Thanks!
The pro version supports USB ELM adapters which are use 'Prolific' or 'FTDI' chips
* Update: A freeze/hang workaround has been found after a great amount of effort and is available in the full version in the General Preferences settings!
