Aplicações alternativas ao Carwings para Android
mikexilva
Moderador Global
Mensagem por mikexilva »
Estava a procurar pela app oficial da Nissan (num tablet) e dei com esta nova app:
https://play.google.com/store/apps/deta ... eafmanager
Que pelos screenshots parece podemos ter um widget que mostra no homescreen o estado da bateria, etc ;)
E segundo a descrição faz algumas coisas que a versão do Carwings oficial da Nissan não faz na Europa..
Leaf Manager (by Gyathaar)
[IMG]https://lh6.ggpht.com/TcAmvd0U40Y0P1JYl ... iE3HE=w124[/IMG]
Descrição
Application for controlling charging and climate controls on Nissan LEAF using the Carwings service.
Alternative to using the official Carwings apps from Nissan.
Allows setting timer for climate control (not available in Nissan's official European Carwings app)
Allows setting charging timer (not available in Nissan's official Carwings apps)
Allows login to European, USA and Canadian servers.
Unknown at this time if logging in to Asian servers works properly. (need feedback)
Also allows login to European server used by official android app
(Note! no support for climate or charge timers on this server, but login is much faster)
In app purchasable home-screen widget.
In-app purchase to disable advertising
PS! You can click the battery bar on the widget to bring up the normal app.
Important!
If you purchase the LEAF Manager widget, you have to manually add it to the home screen using one of these methods:
- Press Home button followed by Menu button. Select Add -> Widgets -> LEAF Manager.
- Press Home button to show the home screen. Tap and hold your finger on any available space, select Widgets -> LEAF Manager.
if ICS or above
Touch the App drawer icon – usually in the lower right hand corner
Touch Widgets at the top of the screen
Touch and hold the LEAF Manager widget
Drag the widget to the particular spot on a Home screen
Drag right or left to put it on a different Home screen
Release to set it in place
Note:
Procedures to add widgets on home screen might be different in devices from various manufacturers with their custom user interfaces.
[IMG]https://lh3.ggpht.com/L0ukfxzCte_g5sYMT ... cp29RguXqQ[/IMG]
[IMG]https://lh4.ggpht.com/4AwtOUIw9_3x8k7EX ... e2WEz53o1a[/IMG]
[IMG]https://lh6.ggpht.com/Ek_jj_cF8EC1Aeh-P ... jSZ7y6vQqg[/IMG]
[IMG]https://lh3.ggpht.com/FZ8l7iz7weAGeY2OK ... Hq7FMS1q8w[/IMG]
[IMG]https://lh5.ggpht.com/pRF01oxgf6ldWDhQC ... KbwoO7oXJk[/IMG]
Depois ainda existem mais umas quantas relacionadas (além da oficial da Nissan)
Nissan Leaf Range Estimator
https://play.google.com/store/apps/deta ... fRangeCalc
Nissan LEAF Field Calculator
https://play.google.com/store/apps/deta ... n.leafcalc
Open Wings FREE
https://play.google.com/store/apps/deta ... wings.free
LEAF Control
https://play.google.com/store/apps/deta ... eafcontrol
Quem quiser um carro alternativo em vez de uma aplicação alternativa, também já existe uma versão beta para o Tesla Model S;)
https://play.google.com/store/apps/deta ... tors.tesla
[IMG]https://lh5.ggpht.com/jw0tb48nYA3jn6_Ih ... wcLIQ=w705[/IMG]
The Tesla Model S Beta app puts Model S owners in direct communication with their cars anytime, anywhere. With this app, owners can:
- Check charging progress in real time and start or stop charge
- Heat or cool Model S before driving — even if it's in a garage
- Locate Model S with directions or track its movement across a map
- Flash lights or honk the horn to find Model S when parked
- Vent or close the panoramic roof
- Lock or unlock from afar
[IMG]https://lh5.ggpht.com/0Pd8ed4IUwHMgv3d2 ... Iy4OCdYJ1c[/IMG]
